Salta al contenuto principale
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
Wifi and Bluetooth not working [LG G3 D855]
Both wifi and bluetooth have stopped responding. I cannot even turn it on. Phone is in good shape and just replaced the display. Problem began before lcd replacement but then it was just a weak signal or sometimes it break the connection. Any ideas?
Questa è una buona domanda?
Punteggio 2
1 Commento
This didn’t work at all for me.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Regarding the weak signal first.
It may be that the WiFi / BT antenna cable has become loose from its' connection to the systemboard.
Here is a link to the ifixit LG G3 D855 Teardown guide. At Step.10 in the guide you can see the antenna location.
As for not turning on. Is the Settings > Wireless and Networks > Wifi ( and BT) enable setting "greyed out" or won't hold when slid to On or that it just can't find a signal etc?
If it can't find a signal see above.
If cannot turn on then try the following:
1. Try starting the phone in safe mode to check if you can enable the WiFi / BT.
If you can then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
2. If still no good in safe mode then try a factory restore (also known as a hard reset), of the phone to see if this resolves the problem.
Be aware that a factory restore will erase all your data and downloaded apps. It will restore the phone to its' factory default condition (or last system updated condition)
Perform a backup of the phone before you try a factory restore, using the phone's backup feature.
Once the backup has been performed, restore the phone using the phone's factory restore feature.
Once the phone has been restored to its' default condition, check if the WiFi / BT can be turned on and that you can detect networks / devices etc.
If it still doesn't work then there is a hardware fault with the phone (most likely the WiFi/BT controller on the systemboard)
If it works OK, then restore the phone, from the backup you made earlier, using the phone's restore feature.
Once the phone has been restored back to "normal", check if the WiFi /BT is OK.
If it is then the restore (reset) has resolved the problem.
Punteggio 3
1 Commento:
Can I just cancel the Wifi&BT hardware that on the board?
Or make it not working cuz I have the same problem but in my case the Wifi&BT is being turned on and off and I can't stay on one condition (On or off)
da
Wiping and resetting the phone doesn’t help!!! I don’t know if this is a permanent solution but so far it’s working for me:
Go to setting -> apps-> click the menu at the top to “show system”.
Scroll down to wifi, click on it. Click storage. Clear all data. Reboot the phone.
Working at the moment!
Punteggio 0
Aggiungi la tua risposta
Gethard Hanawald sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 13,541
