Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Panoramica Video
Questo smontaggio non è una guida di riparazione. Per riparare il tuo LG G3, usa il nostro manuale di assistenza.
  1. Remove back cover by fingernail easily. Remove back cover by fingernail easily.
    • Remove back cover by fingernail easily.
  2. Remove battery.
    • Remove battery.
  3. Remove these 12 screws and remove the back frame. Unlike iPhones, these screws are all the same length. The top part of the frame comes with the power button flex while the bottom part of the frame comes with loudspeaker. Remove these 12 screws and remove the back frame. Unlike iPhones, these screws are all the same length. The top part of the frame comes with the power button flex while the bottom part of the frame comes with loudspeaker.
    • Remove these 12 screws and remove the back frame. Unlike iPhones, these screws are all the same length. The top part of the frame comes with the power button flex while the bottom part of the frame comes with loudspeaker.
  4. Remove the black, shorter screw and pry up the power & volume button flex cover. Remove the black, shorter screw and pry up the power & volume button flex cover.
    • Remove the black, shorter screw and pry up the power & volume button flex cover.
  5. Carefully loosen the power/volume flex from its adhesive. Carefully loosen the power/volume flex from its adhesive. Carefully loosen the power/volume flex from its adhesive.
    • Carefully loosen the power/volume flex from its adhesive.
  6. And finally, remove the flex.
    • And finally, remove the flex.
  7. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Release the digitizer and LCD connectors. The two cameras are held slightly in the frame. Carefully  remove the motherboard with cameras. Release the digitizer and LCD connectors. The two cameras are held slightly in the frame. Carefully  remove the motherboard with cameras.
    • Release the digitizer and LCD connectors. The two cameras are held slightly in the frame. Carefully remove the motherboard with cameras.
  9. Remove rear camera from motherboard. Remove rear camera from motherboard.
    • Remove rear camera from motherboard.
  10. And next, remove front camera. And next, remove front camera.
    • And next, remove front camera.
  11. Remove signal cable.
    • Remove signal cable.
  12. Remove vibration motor.
    • Remove vibration motor.
  13. Remove earpiece speaker.
    • Remove earpiece speaker.
  14. Remove headphone jack.
    • Remove headphone jack.
  15. First, loosen the screen flex from the adhesive on the plate. Then heat the screen edges to melt the adhesive sticker. Next, use the guitar picks and opening tools to cut the sticker. First, loosen the screen flex from the adhesive on the plate. Then heat the screen edges to melt the adhesive sticker. Next, use the guitar picks and opening tools to cut the sticker. First, loosen the screen flex from the adhesive on the plate. Then heat the screen edges to melt the adhesive sticker. Next, use the guitar picks and opening tools to cut the sticker.
    • First, loosen the screen flex from the adhesive on the plate. Then heat the screen edges to melt the adhesive sticker. Next, use the guitar picks and opening tools to cut the sticker.
  16. At last, remove the LCD screen. At last, remove the LCD screen.
    • At last, remove the LCD screen.
  17. LG G3 teardown is done.
    • LG G3 teardown is done.
Sophia
Membro da: 25/03/2014
42.517 Reputazione
62 Guide realizzate
Are you able to put it back together?
Ivan Gergi - Replica
Yes the are surprisingly easy to put back together
Hunter destroyer unit -
I have one that is not booting at all. Before that, If it was shut off or if the battery was drained completely it would not power up, even if the battery was at 100%. I would have to remove the battery and hold the power button down for at least 30 seconds. That is not working anymore, it just ill not power on. This reminds me of issues with laptops that typically involve a CMOS battery that is dead or very low. Is there a similar battery (that can be reasonably replaced) in a phone? For it to keep time and retain certain firmware settings I would think there would have to be something like that in there somewhere....
boxfreind - Replica
Hi boxfreind, i've had a similar issue as of heaps of people (search youtuble for blue screen of death). i too thought of the old laptop days of cmos battery and before i seen this site i thought that vibrator motor was the battery lol. anyway, i cant boot my Lg up after 1 year of service (just like many others). people adivse that trying to remove the motherboard and 'clean it' tends to work... i didn't think that was the reason and thought perhaps removing the motherboard was just actually disconnecting the battery from the motherboard to drain the power... but alas, if no battery CMOS then that cant be the reason.
madmac -
quite easy to remove the back , thanks!
Mie Mohd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 224
Tutti i Tempi: 72,045
