Salta al contenuto principale
Lo smartphone HTC One di terza generazione, rilasciato per la prima volta nel marzo 2015. Le principali revisioni rispetto al design dell'M8 includono il processore octa-core Snapdragon 810 e una fotocamera posteriore da 20 megapixel.
Power button repair issues
Hi guys,
I am repairing a HTC M9 that got badly damaged one side, the power botton got stuck in. But it appears the small magnetic part with the plastic that pushes down the power component has came off. Does anyone know can this be replaced (I dont even know what it's called) or does the entire part with volume buttons etc need to be replaced as a unit? Any advice would be great.
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Your best bet is to replace the power button with a new unit This is not easy to get to as HTC has a tendancy to glue everything together in there phones (eg. the motherboard is glued to the battery) But that said hears ateardown guide to help .
Punteggio 3
Aggiungi la tua risposta
Aidan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 17
Tutti i Tempi: 2,720
