P1105 code is not going away
I've replaced map sensor, code still shows. What's the issue?
Questa è una buona domanda?
@smooch a failed MAP/Baro Switch solenoid can give you the same code. Check for more reasons for code P1105 on here If that solenoid does not open then your sensor does not get a vacuum and will read barometric pressure which will trigger this code. Check the solenoid by unplugging the vacuum hose on the sensor and attach a vacuum gauge to that. Start your car and within seconds your gauge should read a vacuum. If there is no vacuum then it is most likely that your solenoid has failed. Of course this will only work if your vacuum hoses are not cracked etc.
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 35
Tutti i Tempi: 4,979
