Salta al contenuto principale
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 Domande Visualizza tutte
Why is my phone glitchy and rice wont help?
After i brought my phone out in the rain it got glitchy and wont stop. Rice wont help and disisembling it wont help eather. I dont wanna call anyone to help because i want to do it myself. What do i do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@aladorluvz123 first off skip the rice. It is absolutely useless. It will not help you fix your phone. All it does it provides a false sense of security. It will not clean your phone, it will not prevent corrosion.
I suggest that first you do not turn on your phone, charge it or try to connect it in any way. Remove the battery from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points still apply to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide Aggiungere immagini ad una domanda for that. Once it is properly cleaned, replace the battery and reassemble your phone. Only after it has been fully cleaned can you properly troubleshoot. Liquid damage is the hardest to troubleshoot and the most difficult to repair since virtually any part/ component may be involved.
Immagine iPhone
Guida
Riparazione danno da liquidi iPhone
Difficoltà:
Difficile
1 - 2 hours
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Punteggio 2
rice doesnt dry all moisture, the motherboard is probably still wet. keep it turned off and take it to a professional as you have put it in rice means you probably don't know how to repair it
Punteggio 1
Aggiungi la tua risposta
Kaylie pierce sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 88
