Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Is my phone screen fixable? (Please Read Description)
Hi,
I dropped my phone bad on its face and when I picked it up there was a black splotch on one side of the screen and vertical green and purple lines covering a decent portion of that same half of the phone as well as the bottom half of the screen being greatly faded. On the left side, some of the touch screen wasn't really usable at all and the screen would shake and reflect the top half onto the bottom half so I would be sort of seeing double. I thought it would be somewhat functional but when I started trying to use it, buttons would press themselves and the lines and splotches have expanded onto most of the screen by this point. Obviously the inside LED or whatever is busted, is that at all fixable or do I need a completely new phone?
Questa è una buona domanda?
Punteggio 0
1 Commento
If you could post some photos that would be very helpful. Aggiungere immagini ad una domanda
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Well the good news is this is definitely fixable. What I would do is replace the Display: Sostituzione schermo iPhone 6s
Part: iPhone 6s Screen
That is a pretty simple and most fixable part on your iPhone! Hope this helps and have fun with the repair. Contact me if you have any issues.
Immagine iPhone 6s Screen
Prodotto
iPhone 6s Screen
$59.99
Punteggio 2
You just need a screen replacement and it will fix your problem.
Punteggio 0
Aggiungi la tua risposta
Matthew White sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,562
