Error code F2 on Dyson AM07 tower fan
Fan showing error code F2 , not blowing air but will still oscillate .
Questa è una buona domanda?
did you have it set on highest level i.e 10 ?
I did and had the same problem after it had been on for 15 mins it stopped working and F2 appeared,
I checked the base motor and it did not seem to be very warm in fact not warm at all !
i checked for F2 but it is not mentioned in any of the below ...
the useless Dyson manual that comes with it, this just shows how to assembly the item, no brainer, nothing about F2 codes etc
Dyson website, totally useless, troubleshooting section does not explain F2 and just tries to sell you Dyson products
I contacted the retailer and they said return the item, they did not know what F2 was though they have sold over 300 units of this model !
if you have this problem, unplug from mains for about an hour then plug back in and switch on, I turned the setting down to say 2 and it ran all night without any problem, I suspect this is an overkill safety feature, I do not know why as even on 10 it is not that powerful, anyway has worked fine ever since, I just put it on high for short periods if required
hope this helps
little message for Dyson if they ever bother to check web feedback, stop producing your models in Malaysia, bring this back to the UK, you charge a high price for your products where for example this fan model AM07 probably costs £50 to manufacture and then you put a price tag of plus £300 on it, bring production back to the UK carry on charging £300, you will still make a packet even with the higher production costs and add ALL the error codes with detailed explanations to your useless manual and website
I had error F2 too. It was a blocked fan motor. after i took it in the right position everything worked.
My F2 error code also came due to friction on the motor: I hadn’t fully tightened the lower four larger screws causing the fan to rub on the bottom ring in the housing. After complete tightening to pull the fan up, no more error code.
I had the issue today and only found this search result. I spoke with Customer Service and they said the F2 code is for not having enough power. Make sure it’s not in a surge protector or extension cord, plug it directly into a wall outlet. If that doesn’t work, Hold the power button on the unit AND remote for 60 seconds and that does a hard reset.
An F4 code is similar, it’s basically a power loss while it was operating. Unplug, wait 1 minute and follow the same directions for the F2 code. He said if that doesn’t work it needs to be repaired/replaced.
Mine was working last night on setting 2 lovely , gone to put it on now bedroom 30c and error code F2 done everything suggested still error code coming up!!
Any other suggetions?
I don't have the original remote, what do i do?
I found that "F2" meant that there was some resistance inside to the fan spinning. Disassembling it again and removing any friction resulted in the fan working fine with no error messages.
I have just just repaired one of these fans that had 3 faults. The F2 error (motor not turning) which needed a replacement motor as it had burned out, and also replacing the oscillation motor, and repairing the PCB as the fan was oscillating all the time when the power was applied.
"BuyItFixIt" on youtube.
The DC300V version is all sold out. Anyone knows if we can instead use the 105V version and just replace the circuit board from the 300V motor (provided its not damaged) and resolder it to the stator. Would that work?
Il mio Dyson pure cool segnala F2
So new filter installed, and I am getting an F4 symbol. Now what to do?
I followed the instructions for F4 and F2 . Have heat but the purifier light is flashing.
Hi I had f2 code came up in Dyson am07 tower fan can someone help me?
When reassemble after cleaning and maintenance make sure slot of impeller lines up to the slot of the motor shaft if not the impeller will rub against the housing causing the error F2.
https://www.aliexpress.com/item/33061823... can get replacement motor cheaply but disassembly is not for the faint hearted…I have gone ahead and bought with the controller board too
Mine just came up with F4. I blew out the base with an air compressor and it's working great.
Usually a fault has a simple repair.
I had this issue as well. I called Dyson and was told that the filter needs changed. I was told F codes are filter. E codes are electrical/power. I was told the filters need changed annually. I just purchased one. They are $75, fyi.
The AM07 fan does not have any filters. Not sure what model you may have asked about, but it wasn't the one being asked about here.
My Dyson air multiplier technology had F2. I waited for an hour as the previous post mentioned, but F2 was still on. My filter is clean.
Here what I did from several trial and error. When I turnedon it showed 10 for few second and changed to F2 again. I unplugged and plugged back, turned on and the moment it showed 10, I pressed power level down to 5 or whatever. This made the fan on.
F2 means there’s friction on the mechanism -some rubbing. You need to disassemble the fan to ease it. Instructions are on ifixit and work. Good idea to have a light lubricant handy for the shaft also.
I stripped it and cleaned fan motor out with long bristle paint brush (lots of little screws) three different sections and now works a treat.
I already done the stripping out and cleaning the impeller. The problem was that the impeller was rubbing on the casing. When I backed out the screws a bit, friction went away and F2 error disappeared. Fan now works better.
I had the same issue, dust had clogged the motor it was still able to be pushed round, but it was stiff, I just cleared as much dust as possible without dismantling it, I noticed it went round much easier, after that it worked fine.
Friend ki repairingFriend ki repairing
Ultime 24 ore: 4
Ultimi 7 giorni: 28
Ultimi 30 giorni: 146
Tutti i Tempi: 65,242
6 Commenti
My dyson fan is blowing air and I have put in a new filter but it is showing an error message of F=
da Jean Fangsrud
My Dyson is giving me an F2 error. Could you tell me how to fix it? Tried to do a hard reset!
da cathi_dugway
My Dyson tower fan says F4 what does it mean it oscillates but no air
da Maurice Juarez
Cn someone kindly tell me how to solve the F2 error code on my Dyson fan
MyrinSA
da Myriam Nieto-Saunders
Upon cleaning the ventilation holes it came up to F2 with burning smell
da Govindhen Raj
Mostra 1 altri commenti
