Salta al contenuto principale
Sony Xperia Z4 (conosciuto come Sony Xperia Z3+ in Europa). Smartphone con display da 5,20 pollici 1080x1920 alimentato da un processore da 1,5 GHz, 3 GB di RAM e fotocamera posteriore da 20,7 megapixel. È stato rilasciato nel 2014.
My phone does not charge
My phone does not charge or turn on, I connect the charger but it does not start the charge, I put the battery in another phone and it works fine. help please that can be. Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi!
I think you should replace the charging port. Maybe the IC has gone bad or something. Follow this guide until step16 to see how.
Punteggio 2
3 Commenti:
I was looking for the same thing, can this part be?
https://www.aliexpress.com/item/T-Parts-...
or it is about another
da
Yeah that's it!
da
Excellent, I will make the purchase, but most likely it takes 2 months at least to get to Peru, so after that time we will know the result. Thanks for your help.
da
Check you power connector maybe its loose or Some dirt inside..
Punteggio 1
1 Commento:
the phone does not have more than 4 months of use and I have it saved several months ago because it is broken and now I want to repair it. But I doubt it's dirt. Which part do you think is causing this failure?
da
Aggiungi la tua risposta
jhulion sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 10
Tutti i Tempi: 2,637
