Salta al contenuto principale
Smartphone Android rilasciato a giugno 2015, prodotto da Samsung Electronics per la rete AT&T. Numero di modello: SM–G890A
Return button stuck on lock
My return button on my Samsung is constantly lighting up. It is making my phone go into spilt screen mode every few seconds without me touching anything.
It is very frustrating as I am unable to use my phone because of it.
Can it be fixed?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hello Emma,
I had previously written a three paragraph answer for you which was flagged as spam and deleted. Sorry but this answer will be brief. The menu button is a very cheap part. To get to the buttons on an S6 Active, you will likely first need to break the screen. The screen is expensive. Remember to backup your data regularly on any device, but in this case certainly backup before attempting repair.
Punteggio 1
1 Commento:
Thanks so much for your answer, it was a great help! But I think I am going to move back to iphone as my screen has broke twice and now this! Samsungs are just too expensive to fix! Thanks again :)
da Condividi
Hello Emma, the button can definitely be fixed, unfortunately though, it may end up as a costly repair.
The menu buttons are part of a small flexible circuit board that includes your charger port. The flex costs practically nothing.
Immagine
However to get to your menu keys at the bottom of the phone, the glued-in-place screen will first need to be removed. This is just an unfortunate consequence of how Samsung assembles the phone and how they waterproof it. Removing the screen is risky, and even an experienced technician may tell you there is a 50/50 chance the screen will crack and never turn on again. The screen (part-only) will cost over one hundred dollars to replace.
Immagine
For now I would certainly suggest backing up your phone's data before you decide on a coarse of action. A local shop may be able to remove the screen without damage, making this an affordable repair. You could also attempt to remove the old screen yourself if you are confident in your own repair abilities. Were you successful in removing the display, the flex you want to replace costs less than a cup of coffee at Starbucks. If screen does crack, you could also order the part yourself and install it at home, saving a bit on what a local repair shop would charge your in labor.
Punteggio 0
Aggiungi la tua risposta
Emma sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 1,588
