Salta al contenuto principale
ThinkPad introdotto nel 2008. Questo computer era destinato al mercato delle piccole imprese che necessitavano di un portatile a basso costo, senza però rinunciare alle caratteristiche principali.
Supervisor Password Thinkpad SL500
Hi there,
I have a Thinkpad SL500, with a supervisor Password, which I do not know. Does anyone have a clue how I get rid of it. As far as I have read, theres no eeprom on this motherboard which I could short to get rid of it. There is no power on or Harddisk password inserted. Removing the bios battery does not help either now it just ask every startup to correct time and date.
Greets Simon
Questa è una buona domanda?
Punteggio 2
1 Commento
My SL 500 too is lock and Iam experiencing the same problem
da
Aggiungi un commento
2 Risposte
Risposta più utile
You'll find a couple of liks to recovery password generators at the bottom of this page:
https://therestartproject.org/wiki/UEFI_...
But according to the Service Manual there is no procedure for resetting the Supervisor Password. You have to replace the motherboard. If you can find and replace the BIOS chip that might be a last resort solution but you’d almost certainly have to source one from another laptop of the same model, in which case you’d be better off swapping the entire motherboard.
Punteggio 1
2 Commenti:
Lenovo is not suported, I have an error code, but it is a code you can lookup in the manual of the SL500.
da
Also cmospwd does not work
da
Probably not the answer your looking for but if you have a heatgun/good soldering skills you could try replacing the bios chip: https://www.ebay.com/itm/BIOS-CHIP-LENOV...
Punteggio 0
1 Commento:
I would rather perfer a solution which does not include replacing parts on the mothermoard. Although if there is a solution like with most other ThinkPads where there is to analize a Signal or short some contacts this would be ok.
da
Aggiungi la tua risposta
Siki sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 1,090
