Salta al contenuto principale
Il Sony XBR-65X850D è un televisore LCD Ultra HD da 65 pollici con retroilluminazione a LED e risoluzione 2160p. Rilasciato nel 2016. Numero di modello: XBR-65X850D.
Replacement screen for tv
Good afternoon . Where can I find a replacement screen. A remote got throw to it. Stupid mistake.ive taken the broke off and the white screenis not damaged. Please point me in the right direction. I spent a fortune on this tv. Thank you again
Questa è una buona domanda?
Punteggio 3
21 Commenti
I have the same issue except I have a 75 inch. Does anyone have a replacement screen for sony bravia xbr75x850f?
da
I need a screen as well for a XBR75X850C sony TV
da
I need a screen for a Sony Bravia 75 inch
X900F
da
Sony XBR85X900F screen replacement required. Please assist. Thanks.
da
i also need a screen tv has never been used out of the box that way xrb75x850c
da
Mostra 16 altri commenti
Aggiungi un commento
3 Risposte
Soluzione prescelta
@websterd panels that size are pretty much impossible to get. If you do find one it will be more than the TV. You can try and do an online search based on the label of the panel, not the TV. Of course you can also try to find your make and model TV that is broken other than the panel, harvest the panel from that one. This is going to be a tough job to find.
Punteggio 5
1 Commento:
I need Sony Bravia 75 inches screen display how can we get it
da
Same thing happened to me. I had to buy a new TV. Even Sony told me it was around 1000$ just for the screen not the
Punteggio 0
https://www.tvserviceparts.com/TV-Video-...
Punteggio 0
Aggiungi la tua risposta
Webb davis sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 26
Tutti i Tempi: 29,119
