Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
iPhone 5s stuck on apple logo and backlight dead after washing machine
My iPhone was left in my pants and it went into the washing machine and dryer as I had forgotten about it. I plugged it in and shone a light on the screen but it was dim and it was stuck on the apple logo and the backlight won't turn on.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@jimmysofat6864 so it is safe to assume that you have not yet taken care of the water damage at all. The very first thing you want to do is to not try to restart, sync or charge the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides. Once it is disassembled, you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for an apple iPhone3G all the points are still pertinent to your phone. Do not forget to remove the EMI shields for proper cleaning. While you are cleaning it, check for any broken, missing or burned looking components. If you have access to an ultrasonic cleaner than that would of course be the way to go. Once it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. It is entirely possible that this is a bad display assembly at best and a damaged board at worst. If so, you do need a microsolderer like @refectio that has specialized on this type of repair.
Punteggio 2
2 Commenti:
Well I just did this and turned it on and the backlight is still dead but I can still see the Apple logo
da
Yep, going to need someone to do micro-soldering on that board to fix the no backlight issue.
You can find people that do micro-soldering / board-level repairs at reputable mobile phone repair shops that offer a no-fix no-fee model.
da
Aggiungi la tua risposta
jimmysofat6864 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 162
