Salta al contenuto principale
La Golf MK4 venne introdotta per la prima volta in agosto del 1997, seguita da una versione berlina (VW Bora o, in Nord America, di nuovo VW Jetta) in agosto del 1998 e una nuova Golf Variant (station wagon) a Marzo del 1999.
Automatic transmission problem - delayed shifting
The problem is that when I start driving I spidometer stays at 0, and then at some point it "jumps" and shows real speed, in that moment the transmission shifts to next shift.
Also I hear a lot of banging when shifting, so do you have any idea what is happening? One more thing, when I connect car to diagnostics I get g68 error.
Sorry for my bad English
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There is a TSB 01-07-09 for your vehicle covering the G68 speed sensor. A faulty connector wiring is apparently the problem.
Go here and you can read about it yourself it also instructs you how to fix it. But at least it will give you some good information.
Punteggio 0
2 Commenti:
Thanks a lot for response. I've tried to find where the sensor is, but unfortunately I couldn't find it, I've tried on the internet and also with autodata 3.38, but nothing. Can you help me somehow?
da
Try this thrhttp://forums.ross-tech.com/showthread.p..., and read through it. Also has a diagram and written location and instructions.
da
Aggiungi la tua risposta
Enis sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 36
Tutti i Tempi: 2,831
