partially not working touch screen
my phone model is karbonn a81 star, i had replaced touch screen after that the top most part of the screen is not working what is the solution for this pls help me
Questa è una buona domanda?
tvmitc could be either a bad digitizer (most likely) which would need to be replaced once more or a loose connection. Double check your work and make sure that everything is properly connected. If so, contact the vendor your bought the touchscreen from and ask for a different one. Badd parts and poor QA are not an uncommon issues.
when i fixed firstly the home buttom was automatically working at that time the top most portion and the notification bar was working fine ,later i replaced and again when i check the topmost portion was not working and the automatically working problem was solved
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 24
Tutti i Tempi: 741
