Salta al contenuto principale
La quinta generazione debuttò a gennaio 2005.
Why does my engine cut out while driving?
I do have a transmission issue (3rd gear incorrect ratio)
But while I drive my engine cuts off stopped at a stop light without warning and can turn it back on without any issues.
When it shuts down a battery symbol is shown but once it turns back on it goes away.
Can my transmission be the cause of this or would it be something else?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Really need to scan the car for the best answer. However, if it cuts out and shows a battery symbol the best place to start would be the charging system. Need to look at both your battery and alternator to see if A. your alternator is putting out enough charge to keep your battery topped up, should be around 14V. Also if your battery is still in a good enough condition to accept a charge.
A scan though, would be your best bet, as VAG cars can be somewhat temperamental.
Punteggio 1
Aggiungi la tua risposta
Jose sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 41
Tutti i Tempi: 1,259
