Salta al contenuto principale
Guide di riparazione e supporto per la prima generazione del Chevy S-10 Blazer (modello T-10 a 4 ruote motrici), un SUV di medie dimensioni basato sul pickup S-10. Strettamente correlato al GMC Jimmy.
Heating Wires N Stuff
The panel that is directly below where the heating A/C buttons , that you can take off the panel thing and there's a bunch of wires and stuff behind it. I'm trying to figure out what the wires & panel/section itself is called so I can order it all new because a bunch of the wires are frayed or messed up & some of the connection things too.
I'm going to link to a photo of the area I'm talking about.
Link to photo
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
@lusciously that is where your ashtray and the auxiliary power outlets (cigarette lighter) are usually located. As for the wiring, you would need to get complete new wiring harnesses etc. At this time I would not replace those. Get some electric tape and cover the areas that appears frayed to you. Replacing a wiring harness is a major undertaking. Only replace it if absolutely needed.
Punteggio 1
Aggiungi la tua risposta
Kimi Tee sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 8
Tutti i Tempi: 288
