Salta al contenuto principale
Un gruppo di continuità (UPS) è un dispositivo elettrico che fornisce alimentazione di riserva ad apparecchiature critiche in caso di interruzione di corrente o altri problemi legati all'alimentazione.
Back-UPS Pro 1500 - Error: F05
I'm with an APC UPS, model Back-UPS Pro 1500, which is displaying "F05" error, and constant whistle. To repair I need the electric plate (640-3078A-Z_REV07) and service manual. Thanks if anyone can help me.
Questa è una buona domanda?
Punteggio 1
1 Commento
Aggiungi un commento
5 Risposte
Soluzione prescelta
As far as your error, review the guide, here's the error messages:
Immagine
You'll need to contact APC for the part. But you have a deeper problem as the charging logic is damaged 'F05 - Charge Fault
Punteggio 4
@caciola the board is a lot easier to find than the service manual. The board is currently for sale at places like this.
Punteggio 3
1 Commento:
@oldturkey03 - Good find!
da
Hi I also have F05 error . My local Apc service center tells me the unit is NOT repairable . I am thinkin that if I can locate the charging board/unit I should be able to replace it or have it replaced ?
Punteggio 0
I have a Back-UPS Pro 900 from 2012 (BR900GI) that has failed with an F05 error. A local APC service center has quoted me $85 (labour included) for the board replacement. I have no idea what the board number for my model would be, but the 640-3078A-Z_REV07 mentioned above seems to cost about $75 second-hand.
I'd love to keep using this device, but given the fact that a repair and a new battery are needed (it's 4 years old) ... buying a new one may seem a better option? I hate it when this happens!!
Punteggio 0
I simply put in a new battery and problem solved. I tested by putting old, bad battery in another known working unit. It immediately showed F05. New battery tested in both units. No errors. This was in a Pro 1500.
Punteggio 0
Aggiungi la tua risposta
Sergio Caciola sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 26
Ultimi 30 giorni: 117
Tutti i Tempi: 18,379
