Salta al contenuto principale
Guide di riparazione e informazioni sulle bilance alimentari da cucina.
My Arcosteel kitchen scales will no longer turn on
My (expensive) arcosteel kitchen scales no longer turn on. I've checked the battery (It's OK). Any ideas on how to fix?
Wom Bat
Questa è una buona domanda?
Punteggio 0
3 Commenti
Hi @wom_bat ,
Just a suggestion.
How old are the scales?
Don't know about Arcosteel but other makers offer up to a 10 -15 year warranty on their scales
Check the warranty statement (usually in the User guide) for your product as Arcosteel doesn't seem to mention it on their website. Neither the scales or any warranty information.
da
There's a five year warranty that expired last year.
In the meantime, I've pulled the thing partly apart, and replaced the on-off switch which was stuck open-circuit.
da
Replaced the on-off switch which was stuck open-circuit. Now it is working fine.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
This is a hard gadget to get apart. However, removing the three posidrive screws (one under a `warranty void if removed' sticker) allows prying the case apart enough to get at the on-off switch. It's a fairly common 3mm square button switch; I replaced it, and the scales work again.
Punteggio 0
Aggiungi la tua risposta
Peter Chubb sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 21
Tutti i Tempi: 545
