Salta al contenuto principale
L'LG G4 è stato rilasciato negli Stati Uniti all'inizio di giugno 2015, concentrandosi come sempre su specifiche di fascia alta e un gusto estetico raffinato che lo rende distinguibile nel mercato degli smartphone di fascia premium. Ogni versione del telefono avrà un numero di modello differente in base al fatto che sia venduto da un operatore o sbloccato (statunitense o internazionale). Alcuni LG G4 sono noti per avere problemi di bootloop.
Phone not accepting Sim Card
So my old LG G4 (H815 Factory Unlocked) isn't playing ball with my Boyfriends 3 Sim. The phone is confirmed Unlocked and I've been able to use my GiffGaff sim in the phone which further confirms it's unlocked. However it refuses to accept a 3 sim (Both my new 3 Sim; his and one from the store)
I've tried factory resetting the phone a number of times, rebooting, opening it up and inspecting the prongs. Nothing; any advice?
I've also fiddled with APN settings and LTE/GSM settings.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
While this is likely a hardware issue with the cellular radio, try another SIM card. It doesn't need to work, so use a dead SIM that's been deactivated or an expired T-Mobile SIM. The other option is to buy a prepaid SIM card kit from Net10 or Tracfone since the phone isn't carrier locked.
If you continue having issues, there's a problem with the cellular radio or SIM slot. If you're comfortable with board level repair, you can try to troubleshoot further. f you are not, then you're going to need a new motherboard.
Punteggio 4
4 Commenti:
See, I failed to mention that it did detect the sim once, it had a data value but no connection. I think a motherboard replacement may be in order though.
da Condividi
That could mean the SIM is inactive. If you know with 100% certainty it's active then it might be the board.
da Condividi
Sim is 100% active; it's been working in another phone. Sounds like a mainboard issue
da Condividi
Sim card not working other phone simcard is working
da Condividi
Aggiungi la tua risposta
Finlay sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 7,514
