Salta al contenuto principale
La Chevrolet Cavalier è un'automobile compatta prodotta dal 1982 al 2005 da General Motors.
Remove Bench Back Seat
How do I remove the bench backseat?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione prescelta
Force the lower end of the bench seat back toward the trunk to release to clips at the bottom of seat and lift out--You will find either clips or screws at the lower end of the upper portion of seat--release these and lift upper section of seat should release from locking clips allowing removal of upper section
Punteggio 7
7 Commenti:
am amazed by the things you know! ;-)
da Condividi
ah shucks ma'am
da Condividi
How do you get the clips to reatatch thanks
da Condividi
Does anyone know what these locking clips are called? They are broken and I cannot put a car seat in my car because of it. I need to order new ones ASAP
da Condividi
i cannot seem to locate any hardware on mine. looks like its a pin on both sides, and this runs straight into the seat. I've removed the lower seat, cannot get the fold down part out.
da Condividi
Mostra 2 altri commenti
if your release strap on your upper backseat is broke, stick a pair of needle nose pliers in the opening right in the middle of the upper backseat grab the latch and pull. now just go do it.....
Punteggio 0
I took the seat out and broke the clips because I didnt read anything first. Like a idiot. What is the best way to replace the clips? Or just buy a new backseat?
Punteggio 0
Aggiungi la tua risposta
Mark sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 36
Tutti i Tempi: 22,807
