Salta al contenuto principale
La serie Signet rappresentava la linea di punta di fotocamere 35mm prodotte in America da Kodak negli anni '50. È uno dei soli due modelli Signet dotati di telemetro e l'unico non realizzato principalmente in plastica.
double superimposed rangefinder patches problem
When view through viewfinder on kodak signet 35 , the rangefinder patch appear from 2 triangle 70% superimposed but slightly shifted horizontally on left side.I could not discern what would cause one triangle to split into two, though I suspect it's a a misalignment. What area should I be inspecting?.I wait for yours ideas.Thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Sostituzione del divisore di fascio della Kodak Signet 35. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
Punteggio 3
3 Commenti:
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
da
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
da
Thank you very much
da
Aggiungi la tua risposta
Florentin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 8
Ultimi 30 giorni: 19
Tutti i Tempi: 777
