Salta al contenuto principale
Quadricottero con gimbal per fotocamera preinstallato, videocamera 4K e trasmissione video wireless.
Why doesn't my drone start?
i go through the start up process, calibrate the compass, and when I pull back on the controller levers to start the motors, blinking green lights on the drone go to red and it does not start. I have repeated the process and sometimes it does start and fly as it's supposed to but most of the time it does not.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
well I would start with what I know, batteries are full in both units ?....I think you've flown this combo before, did anything happen since your last flight, maybe a "light" crash , radio (controller) get "bumped" off the kitchen table? it doesn't take much for a pcb to break a connection just to ruin your day. Without turning screws and opening anything up (not recommended) their are only a couple things it could be, I would start with the batteries
Punteggio 1
1 Commento:
I have 3 batteries and I have the same issue with all 3 fully charged. No crashes or bumps. It did set up unused for about a year but it was fine for the first 5 or 6 flights before this issue started. I thought maybe it was the Wifi extender but I'm still experiencing the same problem after changing it.
da
Aggiungi la tua risposta
Alvin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 11
Tutti i Tempi: 585
