Salta al contenuto principale
Il primo modello della linea di personal computer iMac realizzato da Apple. L'iMac G3 è stato prodotto tra il 1998 e il 2003.
Glow or light up
I've been given an iMac G3 which is almost perfect. I've put OS 9.2.3 on it which runs fine.
The only problem is the blue shell does not light up or glow?
Searching the Web I came across a statement that there was a bulb somewhere near the round plastic handle but I can't see one.
Anyone know how to get it glowing again please?
Questa è una buona domanda?
Punteggio 1
1 Commento
Thanks for your help - I must have believed some hype Apple Advert I saw in 1998!
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hello,
I was looking up teardown of this particular model and I can't see anywhere the above mentioned light.
If you can provide me the link where you found that it was glowing at some point there is always a way to fix by the way could be steep because of the age of the machine.
You can look up how hard it's even to open this thing up:
https://www.youtube.com/watch?v=j-w-3LZi...
Punteggio 3
8 Commenti:
That's modding, the MAC didn't have that built in.
da
You can send the MAC to experienced electrician/computer scientist if you want that the light is powered from inside from the computer. If you want to do it yourself without knowledge for computer science and electricity you can drill(somehow make) the hole and push the led strip inside powering it from outside with a cable.
da
If this answered you'r question please rate it and mark it solved so others looking for this subject know what's going on. Thank you.
da
I thought they were sold in a range of different colours and lit or glowed from new not that they had to be modified?
da
Mostra 3 altri commenti
Aggiungi la tua risposta
Denny Tuckerman sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 11
Tutti i Tempi: 688
