Salta al contenuto principale
Presentata al Salone dell'automobile di New York del 2004, la Xterra è stata riprogettata per il 2005 sulla piattaforma Nissan F-Alpha utilizzata dalla Frontier, entrando negli showroom nell'aprile 2004 per l'anno modello 2005.
No Acceleratror pedal control
I got a code p2122, accelerator control sensor on my 2005 Nissan x trail. I have changed the pedal control sensor and the fuel control on the intake and checked the connectivity of all 6 wires from the pedal to the control body and all seems to be fine. I still have engine light on with code p2122 and no response to the pedal still. Where should i go searching now?
Questa è una buona domanda?
Punteggio 3
1 Commento:
I now have this problem also. I have replaced the throttle body and the pedal sensor and still the gas pedal does not work. Have you finaly solved the problem and what was the repair if so? Thank you.
da
Aggiungi un commento
1 Risposta
It is possible it could be a bad throttle body module. The code that you got basically means that the PCM is seeing low voltage (below .17) on the throttle position sensor circuit. Usually this is a pedal but it's possible to be the throttle position sensor or the actuator motor. Both of which are serviced in the throttle body. The throttle body is available on the aftermarket if you don't want to go factory.
Punteggio 0
Aggiungi la tua risposta
Lonny Nohnychuk sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 25
Tutti i Tempi: 2,727
