How to replace front glass?
I would really appreciate a guide on how to replace the front glass for my daughter's 2014 kindle. thank you in advance foe any help.
Questa è una buona domanda?
you are not telling us the exact Kindle that you need help with . The device you picked is the FireHD 7 and you can use this guide Sostituzione display Amazon Fire HD 7 (4ª generazione) for that
matthew santiago you will have to follow the above guide in its entirety. You then need a heat-source like a good hairdryer or a hot air gun at it's lowest settings to soften the adhesive that holds the touch screen to the frame. Soften it with the heat-source and remove the touch screen with same plastic tools like guitar picks etc. Check this video from 7:54 and proceed identically to it.
I am requesting info on repairing the glass, not the LCD.
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 806
1 Commento
This question is in the Amazon fire hd 7 section.
da matthew santiago Condividi
