Salta al contenuto principale
Dispositivo di sicurezza domestica all-in-one rilasciato nel 2015. Il Canary CAN100USBK è una videocamera 1080p con Wi-Fi dotata di una sirena da 90 decibel.
Disabling the LED light ring
Is there an easy way to disable the led light ring on the base of the unit please?
Questa è una buona domanda?
Punteggio 0
2 Commenti
I just bought a All in one. Bummed that it does not work in a window looking outside due to IR lights glare. I also wondered about white light on bottom. Am thinking of covering it with electrical tape. Careful not to cover anything on the bottom. I did put tape over the IR lights, but that defeats the ability for night vision. I guess I am asking the device to do something it is not designed to do. Most likely will be returning it.
da Condividi
Canaryman, what did you end up doing?
da Condividi
Aggiungi un commento
3 Risposte
Risposta più utile
If you mean the red one that you only see when it is kind of dark, I believe that is the night vision.
"Those small red lights around the CCTV cameras are called IR LED or simply infrared LED. They're used to supply lighting for security cameras to see in dark and low light conditions which are turned off at day
time." -Quora
Punteggio 1
6 Commenti:
Thanks for your response Aiden but i meant the white ring on the underside of the unit which is a bit of a giveaway if anyone broke in.
da Condividi
Well, keeping it would notify potential thieves that you have a camera and that could scare them off. Much like those signs people have in their yards to say they have an alarm system. those signs scare potential thieves away. just showing you have security measures set up could avoid a potential robbery! https://www.safewise.com/blog/do-fake-se...
da Condividi
Thanks once again Aiden.
I would however like to know if there is a method to disable the light ring rather than whether it should be disabled or not.
da Condividi
ah yeah. Sorry. according to the manufacturer's website, there's an app. but if you cannot disable it there, that's poor design on their part and you may have to cut a wire.
da Condividi
If you don't want to permanently disable it Probably just cover it with duct tape.
da Condividi
Mostra 1 altri commenti
I found this: https://help.canary.is/hc/en-us/articles... maybe that couod help
Punteggio 0
luz roja intermitente
Punteggio 0
Aggiungi la tua risposta
Canaryman sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 36
Tutti i Tempi: 8,811
