Salta al contenuto principale
Informazioni per la riparazione dello smartphone Sony Xperia X, annunciato a febbraio 2016 e rilasciato a maggio 2016. Questo telefono fa parte della serie di telefoni Xperia X di Sony.
Possible back light problem
i broke my phone recently for the second time.....first time screen broke...got the parts fixed it, was all good.......this time it was the touch screen that cracked...and a little while after it went black....didn't think much of it and ordered the parts......
I've replaced the screens over but still no display, i held it up to the window and saw the screen faintly, so i took the screen off the phone (still connected) and i could see my display when it was held up to the light at an angle..... is this the back light? and if so is there a way to fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
@gazf5 yes it is . Problem you are running into here is that Sony no longer has any schematics available. Since you already changed the display your issues will be on the circuit board. This may be harder to repair then it appears because of that. you could try and do an online search for backlight ways and see if anybody has figured this out yet.
Punteggio 1
Aggiungi la tua risposta
gazf5 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 10
Tutti i Tempi: 752
