Salta al contenuto principale
L'HTC Desire 610 è uno smartphone touchscreen che utilizza il sistema operativo Android. È stato rilasciato nel febbraio 2014.
hard reset is needed
There was low battery yesterday and it shut down. I put it to charge and in the morning when I tried to turn it on it started to turn on and off. I tried to reboot, tried to do recovery and tried to do factory setup from hboot recovery menu but its still restarting. what can I do ? can I do something without using PC ? thank you beforehand
Questa è una buona domanda?
Punteggio 0
1 Commento:
Its possible that you might have to some how find and flash the stock firmware. I am not sure as i have not messed with many HTC phones not have i seen one fail after a battery drainage.
da
Aggiungi un commento
1 Risposta
The "turning on and off" doesn't sound like you need a factory reset.
Try
a) a different or higher Amp charger. Normally they are 5v/1A, try a 5v/2A.
b) have someone look at the battery.
Punteggio 0
Aggiungi la tua risposta
Sarvar Saidov sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 283
