Salta al contenuto principale
Guida di riparazione e informazioni per la risoluzione dei problemi per il mouse wireless Apple con supporto multi-touch. Numero di modello A1657 o A3204.
Cannot select with MM2.
Cannot select with MM2. I can move cursor but cannot click. Also disables my ability to select on trackpad. If I turn off MM2, trackpad functions normally.
Questa è una buona domanda?
Punteggio 3
1 Commento
Hello!
I had the same problem with the MM2. I could move the pointer but it did not go right or left click. Have a reset of the mouse performed, tried on another Mac.
Nothing worked!
Then I disassembled the mouse according to ifixit instructions and, as in step 7, disconnected and reconnected the data cable.
And the mouse works again like the first day!
I hope I can help some users with the info, because I found nothing on the Internet.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Try going to system preferences > trackpad > see if "tap to click" box is checked.
Punteggio 2
2 Commenti:
Thanks, I can select with the trackpad as long as the Apple mouse is disconnected. I am using a cheap external mouse and getting by. I think the Apple mouse is my problem. At $75 I'm going to have to make do with the off-brand mouse. It has made me become more proficient with the trackpad.
da
Well. get a used one, I just bought 4 for $45 https://www.ebay.com/usr/tricomputersolu...
da
Aggiungi la tua risposta
James M McMurtry sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 27
Tutti i Tempi: 1,512
