Salta al contenuto principale
L'Essential Phone è lo smartphone di prima generazione di Essential, rilasciato nell'agosto 2017. È disponibile nei colori black moon, stellar white, stellar grey e ocean depth.
SIM Card not recognized after drop
I dropped my phone last night, and now it thinks it doesn't have a sim card. How can I fix this? I've tried restarting it, but it cannot make calls, texts, or go online.
Questa è una buona domanda?
Punteggio 14
6 Commenti
Actually, the ejectable sim tray had popped out part way and hadn't seated properly shut again. Problem solved!
da
Dropped my phone and was super bummed . Came across this and it worked . You’re a life saver brotha , good thinking . Thanks G 🤙🏽
da
I didn't get a sim card when I received my G33 BLU PHONE. SO WHAT IS THE DEAL???
da
I have the phone but I don't have a SIMs card
da
I had the same problem was able to fix with a twist. I used clear packing tape . 3 layers across top of sim card and part on card holder. sild in, bingo,, no circle with line through!!!
da
Mostra 1 altri commenti
Aggiungi un commento
5 Risposte
Soluzione prescelta
if the sim card is not reading, there is a high likelyhood something got damaged in the drop. either the sim reader itself, or, more likely, the logic circuit for the sim reader.
if you replace the sim tray, and it doesnt fix the issue, then the logic circuit is failing, and that would need to go.
Punteggio 11
2 Commenti:
Insert Digicel sim card to a Voda android phone
da
1150001700014884 किस नंबर लिंक है
da
Risposta più utile
I solved this same issue, this might work for you too. Shut off your phone. Pop out the SIM card and place it on a thick piece of paper, use an exacto-knike to cut an outline of the SIM card on the paper. You can also draw an outline with a pen/pencil of the SIM and cut the outline. Try to be as precise as possible and dont exceed the outline, trim excess if needed. Then place the paper cutout in the SIM tray, place the SIM above the cutout on the SIM tray and pop it back in. Turn on your phone and you should get signal. If the SIM cant be popped back in, use a thinner paper, likewise, if this solution doesn’t work, test it out with a thicker paper/multiple layers of thin paper.
Punteggio 38
47 Commenti:
Worked for me perfectly !! Many thanks !’
da
Like which side should the paper be on the gold side or white side with numbers
da
It works again thanks so much :)
da
Wow. This actually worked. However, the way this is written implies you put the paper below the sim card in the tray. doing that you're blocking the contact points. the paper goes ABOVE the sim card, I assume this presses it down further. Thanks for this tip, though. Saved me a thousand bucks for now.
da
This worked on my iPhone 13! Amazed! Paper goes on bottom of sim card on iPhone.
da
Mostra 42 altri commenti
i just wiggle my sim card in and out and continue to turn my phone on and off
Punteggio 2
1 Commento:
This worked for me - brilliant
da
I ended up with two pieces of paper and it fixed the SIM issue.. But my issue returned when I tried to put it back in Otter case. Seems like there is some twisting of the phone that occurs when trying to put the case on. Solution might be to find a different case. Stayed tuned.
Punteggio 2
Haven’t taken it to a repair shop yet, but I have reset the phone, took the sim out, cleaned it, wiped the phone to factory settings, and it flashes "SOS only" and "No SIM".
Punteggio 0
Aggiungi la tua risposta
Emily sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 71
Ultimi 7 giorni: 420
Ultimi 30 giorni: 1,970
Tutti i Tempi: 170,134
