Salta al contenuto principale
La stampante multifunzione a getto d'inchiostro HP Officejet 6600 è un dispositivo 4-in-1 in grado di stampare, scansionare, copiare e inviare fax.
Ink system failure message
The message says the printhead appears to be missing, not detected, or incorrectly installed.
I uave done everything HP told me to do and I still have this error. It looks like the black ink spilled inside the printer. Xan I have this repaired or should I just get a new printer. I have already tried to clean all of the ink out but I can't reach inside to get it all out.
Questa è una buona domanda?
Punteggio 1
2 Commenti
I tried one thing once. And it worked then it messed up again. Now it says print head appears to be missing,not detected, or incorrect.y in
Stalled
da
It worked for me on the, ow it doesn’t work
da
Aggiungi un commento
1 Risposta
Risposta più utile
Printhead issues are very common in this line of printer. I believe you can replace this yourself. You can simply use a cheap refurbished from Ebay. ($29 ish)
Here is a printhead replacement video for a 6700
https://www.youtube.com/watch?v=jSPXV3an...
Punteggio 2
Aggiungi la tua risposta
Sam Bird sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 15
Tutti i Tempi: 2,698
