Salta al contenuto principale
Action camera released by GoPro in October 2013.
60 Domande Visualizza tutte
Will not power up. Does not show up when plugged into computer
Will not power up. Does not show up when plugged into computer. tried new batteries and taking them in and out a bunch of times to try and reset. no lights at all
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Ephiram Bosse time to take a closer look at it. you do want to check the battery connections to make sure that the battery provides power on the connector. After that you want to check the micro USB connectors on the motherboard to make assure all of that is connected/soldered. Post some pictures of your boards so we can see what you see. Use this guide Aggiungere immagini ad una domanda for that and use this guide GoPro Hero3+ Black Edition Motherboard Replacement to work on your GoPro
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine GoPro Hero3Plus Black Edition Motherboard
Guida
Difficoltà:
Moderato
10 - 15 minutes
Punteggio 2
Aggiungi la tua risposta
Ephiram Bosse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 38
