How do I replace latch pin?
How do I replace the latch pin?
Questa è una buona domanda?
@noreenmcgrath check the diagram and see if you are referring to the catch pin (25) or the hinge pin (49).
From the SM
Catch Pin and Quadrant Assembly
Post some images of the pins etc. with your question. Use this guide Aggiungere immagini ad una domanda for that. That way we can see what you see.
Hi @noreenmcgrath ,
The part that I referred to in my answer to your earlier question Mixer opening when mixing is #25 . It also says that full instructions will be given with the part.
Hopefully this adds to @oldturkey03 excellent answer
Connect top slide facing downwards towards the machine not sideways. Slide latch assy through with the handle going through the slide. Place plastic attachment through hole on the left with spring and connect spring on the wall that the plastic piece is in. Turn until you have tension where the round area is towards the the insert hole. Your handle should be facing down. When you close it should catch. Any more questions shoot me an email at lapsuslingue@yahoo.com
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,406
