Salta al contenuto principale
Le cuffie Sony Extra Bass, modello MDR-XB450AP, sono un paio di cuffie di alta gamma prodotte da Sony. Sono dotate di un microfono omnidirezionale per le funzionalità Bluetooth.
Right side not working
In the gym, i the wire of my headphones got pulled during my workout. Since then, I the right side is not working. I followed a guide to disassemble the right side of the headphones and found that the solders to the speaker were intact. Everything seems fine, I don't doubt any damage to the speaker, as they were working fine just before the wire got pulled. What else could the problem be? I am attaching a few photos after disassembly, please look into them and report the cause as to why the right side is not working.
P.S. The left side is working fine.
Questa è una buona domanda?
Punteggio 10
8 Commenti
Hey Vikram, I have same problem with my headphones? Did the other mentioned solution worked?
da
Mawose, I'm sorry for making you wait for the 3 days for the anwer, but the answer did work. Actually, I found out that this problem often occurs because the one of the solders at the jack has got loose, or at times broken.
da
What part is the broken part?
da
It's the same problem of my headphone but I can't find the source of problem can you help me
da
Can you provide a picture of the problem? Since i dismantle my headphone i don't see any problem in the wire they're still intact.
da
Mostra 3 altri commenti
Aggiungi un commento
1 Risposta
Risposta più utile
Your head phones wire broke off from somewhere in between the pin and the right side speaker connection which is quite thin .
Punteggio 1
1 Commento:
thank you Chris
da
Aggiungi la tua risposta
Vikram Choudhary sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 24
Tutti i Tempi: 6,268
