Salta al contenuto principale
Un tablet rilasciato da Hisense nel 2014, identificato dal numero di modello E2281.
How much to fix screen?
Tablet screen is cracked but still works. How much to fix?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
this isnt a repair shop tania you would be better trying somewhere close to you
Punteggio 1
@twaide iFixit does not do repairs. Here you can get advice on how to fix things by yourself. You did not tell us if it is the glass/digitizer that is broken or if it is the LCD that is broken. The digitizer will cost you around $10USD and the LCD around $20USD The trick here is that it is a slight offbrand tablet and there is not a lot of information out about it. Use these guides Hisense Sero 8 and a slightly different model Hisense video from here to see if you can repair it yourself.
Punteggio 0
Aggiungi la tua risposta
Tania Waide sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 23
Tutti i Tempi: 658
