Salta al contenuto principale
I modelli statunitensi sono stati messi in vendita come veicolo dell'anno modello 2012. I primi modelli includono la scelta tra carrozzeria berlina a quattro porte o hatchback a cinque porte, motore DOHC da 2,0 litri (148 CV), cambio manuale a cinque marce o CVT Lineartronic con modalità manuale a sei marce tramite paddle al volante.
Key will not release
2013 Subaru Impreza
Key will not release when we shut the engine off. We have already troubleshot several steps. Brake is applied, transmission firmly in park, pushing key inward while turning engine off. Engine shuts off but will not complete cycle so that it can be removed.
Questa è una buona domanda?
Punteggio 2
1 Commento
Hi don, is the steering wheel locked? Make sure that is can turn a full 360.
da Condividi
Aggiungi un commento
3 Risposte
Risposta più utile
I had this issue with my 2016 Impreza. After pulling apart the center console, I figured out what was causing my issue.
To move the shift knob the driver needs to squeeze in the button on the front (blue circle in the picture). This lifts up a rod through the knob (red line in picture) . with the rod up the shift knob can be moved into gear. The rod also presses a button when in park, releasing the key. My issues was the rod was not dropping all the way down and activating the switch. I pulled the rod out and put some light grease on it, hasn’t been a problem since. It was not to much work to get the rod out but I don’t remember exactly how.
Immagine
Sorry its so late, maybe this will help someone else
Punteggio 2
If it has a locking steering column, the wheel may be turned too far. Turn the key while jerking the steering wheel back and forth fractionally.
Punteggio 0
Included with the above recommendations, I depress the brake pedal while removing the key. This might help.
Punteggio 0
Aggiungi la tua risposta
don fagan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 18
Ultimi 30 giorni: 45
Tutti i Tempi: 6,968
