Salta al contenuto principale
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Domande Visualizza tutte
30 inch display has thick line in centre
My 30 inch cinema display has a 3 mm thick black vertical line exactly in the centre.
It started as a thin red line and got a bit thicker and black after a few days. I have it connected to a mac pro 5.1 with sierra and an AMD 280 GPU with a Dvi port.
Does anyone have similar experiences with a cinema display? Looking for a solution to fix this. Any advice highly appreciated. thnx in advance!
Questa è una buona domanda?
Punteggio 0
1 Commento
@macha post an image of what your screen shows with your question. That way we can see what you see. Use this guide Aggiungere immagini ad una domanda for that.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Lines are not good ;-{
If the line is static not moving that is a sign of a TAB error. Basically, there is a ribbon connection from the LCD panel to the driver board on the back of the display which has come disconnected from the glass or torn, this is a very fragile connection. There is nothing you can fix here as the connection is severed. Its also possible the driver (TCON) board has a problem as well. Again no good news as you'll have a hard time finding the board as it's not sold as a repair part.
Bottomline: You'll need a new screen assembly as the easiest repair, but even that maybe beyond what you want to spend. As a reference: 30" Apple Cinema Display Replacement Screen You might find a used one for less just be prepared it may have some flaws.
Punteggio 1
2 Commenti:
Thnx a lot for sharing your expertise Dan! Much appreciated. I was already looking for a second hand 30 inch. They go for around 200 to 225 euro. My thought though was that all the 30 inch might have a common certain lifespan. Most of the 30 inch displays are more than 10 years old. I suppose they all get issues now considering their age. I could not find any records of the average lifespan of these displays.....
da
Lifespan is always a tricky question as no one really monitors it. The best one will find MTBF data that the manufacturers list. But that’s based on the design of the components being used.
da
Aggiungi la tua risposta
J.S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 826
