Why is my screen dim
already tried changing the signal cable but its dim still
Questa è una buona domanda?
it could be that the screen isn't being as energy efficient as it used to causing a lower max brightness, look if you can find a small flat knob that a phillips head can fit into to adjust the voltage.
Have you tried System Restore? Or a Last Known Good Configuration?
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 10
Tutti i Tempi: 274
1 Commento
Have you tried changing the brightness using something like Fn+F11/F12?
da Alex Niculescu
