Salta al contenuto principale
Guide di riparazione e informazioni sul dispositivo per lo smartphone Samsung Galaxy J5 Prime del 2016, numero di modello SM-G570Y o G570.
My back key isnt working
My back key and recent keys arent working
Questa è una buona domanda?
Punteggio 10
Aggiungi un commento
3 Risposte
Soluzione prescelta
For the majority of people that own a Galaxy J5, the Touch Key is not broken and is actually working. The reason that these buttons are not working, is because there just disabled and turned OFF. Samsung has a default settings that has these keys turned OFF because the Galaxy J5 is in energy saving mode. Follow these step-by-step instructions on how to turn on the Touch Key lights on the Samsung Galaxy J5.
How to fix Touch Key light not working:
Turn on the Galaxy J5
Open the Menu page
Go to Settings
Select on “Quick Settings”
Select on “Power Saving”
Go to “Power Saving Mode”
Then go to “Restrict Performance”
Uncheck the box next to “Turn off touch key light”
if this does not fix the issue, the charging port must be changed due to these buttons are part of that assembly
Punteggio 7
4 Commenti:
The “Restrict Performance” and “Turn off touch key light” options are not available in the nougat update.
da
I got water on my phone, then my phone was dodgy for a few days until I dried it out but my home button never worked again? How do I fix this please?
da
I think i dropped my phone a few times, bout it didnt stop working right off the bat. But now it is?? I have a samsung j3 emerge
da
I have the same problem I dropped it in water then immidetly dried it then the open apps button and the go back button stopped working how can i fix this some one please help
da
Very Helpful , Thank You .
Punteggio 0
1 Commento:
i have a Samsung galaxy j5 pro and the soft key lights not showing
da
Samsungj5touchbuttonicsnotworkingpleasehelpme
Punteggio 0
1 Commento:
I have Samsungj7 , long not to used it as I have other phone, when I used it I found back button not working.I followed this above advice but the button that mentioned " key light" not available on j7. Any other advice can help?
da
Aggiungi la tua risposta
Dikshant Thapa sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 23
Tutti i Tempi: 76,753
