Salta al contenuto principale
La stampante HP OfficeJet 4630 è un modello wireless tutto in uno a getto di inchiostro a colori.
Always shows error of paper jam
As soon as the device is powered on the printer shows error paper jam. Full disclosure this issue started to happen after a cat peed on it. It worked for a couple of days and now it is showing the same error again
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
cat pee is acidic. this must have caused some parts in the board to corrode and shorted out
Punteggio 1
2 Commenti:
Firstly, why did the cat pee on it?
Secondly, since something is shorted you should check for anything that seems broken and replace it.
da
Was house sitting a friends cat. He must have been confused or something to something so random.
I suspect something similar too. Will have it checked.
I was hoping that I might discover a simple hack that can resolve the issue.
da
Aggiungi la tua risposta
Nishit Rao sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 7
Tutti i Tempi: 995
