Salta al contenuto principale
Repair guides and support for electric shavers, disposable razors and blades, and straight razors, for both men and women.
How to open to get to batteries
Hello, hope this finds you all well. Have an older Panasonic ES8003 wet/dry shaver I need to replace the battery on. does anyone have a breakdown on how to open it up and remove batteries? I have found videos on youtube, but its nor of the same ES8003 model and the disassemble is different. thank you much for any help:)
Questa è una buona domanda?
Punteggio 1
1 Commento
@whansen post some good pictures of your shaver with your question. Include the bottom part. This will help us to see what you see. Also, which video did you check? Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@whansen check the illustration from the manual. There should be two Phillips screws on the bottom that you need to remove, then remove the cap. Hold the case with one hand and with the other hand holding the foil, pull straight up. This should expose the internal workings as well as the batteries for your shaver.
Punteggio 2
5 Commenti:
Hello and thank you very much, for your help and diagram, kind of you. I was able to remove the bottom 2 screws, the bottom cap. I'm not sure if there are two small screws shown in item 2 in the diagram? I removed the blades, the two top phil screws, but I can't get the metal plate off due to the small black plastic clip the wraps around the top to side, do I need to remove these parts to be able to slide unit out of otter plastic case? it moves some but is catching on somethng. battiers are staring to corrode:( thank ou again for all your help
da
I got it all off, needed little more pressure:)
da
Thank you again, I got the old batteries out and cleaner unit with electrical cleaner. I see these two battery options, what do you think about them? https://www.amazon.com/eneloop-Spacers-P...
Or
https://shaveroutlet.com/braun-battery-n...
da
I'd go with those https://shaveroutlet.com/braun-battery-n... because they seem to be a match and will fit appropriately. The Amazon once do not look like they would snap in easy.
da
Hello and thank you very much for your replies and help, kind of you:)
da
Aggiungi la tua risposta
William Hansen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 522
