Salta al contenuto principale
Il Nintendo 2DS è un dispositivo di gioco portatile sviluppato come versione entry-level del Nintendo 3DS con hardware quasi identico, ma senza la funzione dello schermo superiore 3D.
205 Domande Visualizza tutte
2DS crashes when I move it suddenly. Something inside shifts when I do
So, like I said above my 2DS crashes whenever I move it too suddenly. I can hear something shifting inside, and it is definitely not because of the buttons. I haven't had a problem turning it on, but if I move the 2DS when playing a game, the system crashes and often shuts itself off. On another website I read that it is possibly caused because a cover to something came off. I was hoping to fix the problem myself if it is at all possible for someone to guide my through it. Thanks for the help in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Rabbit Bunny from your description it does sound like something is loose on the inside causing your 2DS to "crash" by posibly shortening out some components etc. I'd suggest that you use these guides to open it up and take a look at what you find. Add some good images of that with your question so we can see what you see. For that use this guide.
Punteggio 2
Aggiungi la tua risposta
Rabbit Bunny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 206
