Salta al contenuto principale
Refrigerator and freezer not cooling.
The lights in the fridge and freezer flash non-stop( not sure if these two problems could be related?); this isn't a big deal, because I can just turn the lights off. The second thing is that it just stops cooling in both fridge and freezer out of nowhere. I think when we replug it in it works for a little while, and then stops working again. Thanks! http://www.refrigerator-reviews-ratings....
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This has happened to many others. It appears to be a factory defect. Try unplugging it and plugging it back in. Here is my previous answer on this including the defect link:
Whirlpool Refrigerator Interior Lights Flickering
Punteggio 2
Power Socket or plug Issue , Just make it sure that it has no loose connection,
Please check also the Proper Voltage from your Main AC Source . 220 VAC or 120VAC
Extreme carefully handling Power,
make sure safety first, avoid electrical Shock.
No Wet Floor and Foot upon plugging and unplugging AC Mains.
Punteggio 1
2 Commenti:
Thank you, I'll check that.
da
Your Welcome just keep us posted for the progress ^_^
da
Aggiungi la tua risposta
Sherry Thompson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,157
