Salta al contenuto principale
Il Vostro è stato introdotto come notebook orientato al business per l'utente medio. A un prezzo ragionevole, è stato rilasciato da Dell alla fine del 2008 ed è identificato dal numero di modello A860.
Not seeing the home screen
After switching it, it starts loading then it goes back to the first step of the switching .it goes back before I see the home screen.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@yvette7 I am a bit confused by your question. You need to let us know exactly what your computer is doing and what your operating system is. If it cannot start the OS then it is most likely an issue with the file structure on that and it may need a repair or new install. If it is on the splash screen as your computer loads you do want to try to get into the BIOS and check the settings on that. Consider changing the boot order and use a bootable disk or USB drive to see if that will load on your computer. If so you know that you are having a problem loading your OS. So let us know what you mean by "starts loading" and what "the fist step" is that you see. To access your BIOS try these
Turn on or reboot your computer.
Press "F2" continuously during the reboot process until you see the message "Entering Setup." On some older systems, you may need to press "Delete," "Ctrl + Alt + Enter," "Fn + F1" or "Fn + Esc."
Navigate through BIOS using your arrow keys. Your mouse will not work in BIOS.
Punteggio 0
Aggiungi la tua risposta
Yvette kagoyire sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 280
