Salta al contenuto principale
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
emergency brake light switch
While emergency light on cruise control will not engage
Questa è una buona domanda?
Punteggio 0
2 Commenti
Enoch Vinnegar Jr not quite sure what you are asking. What emergency light on cruise control?
da
Was wondering where the switch that lights up the emergency brake light symbol on dash panel is located so I can change it. As long as this light is lite, my cruise control will not engage
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Enoch Vinnegar Jr there are a few possibilities. One being a bad parking brake switch or a bad switch in your brake fluid reservoir switch. This series has an issue with the wiring to the instrument cluster as well. Check on here for that. The image will show you where the parking brake switch is located
Immagine
and this one
Immagine
where the switch on your fluid reservoir is. You do want to check both of these switches for continuity.
Punteggio 0
3 Commenti:
@oldturkey03 do you have a detailed document on how to remove the emergency brake assembly and driver's wiring harness under the dash? I may be missing information in my Ford tech service manual. I need to remove all this stuff to replace the floorpan. Same generation 2004-2008.
da
@Ben this is for the emergency brake 04 F 150 Parking Brake Still looking for the wiring harness.
da
@Ben see if you can get the 2006 manual from here Let me know when you have it so I can remove the link
da
Aggiungi la tua risposta
Enoch Vinnegar Jr sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 25
Ultimi 30 giorni: 95
Tutti i Tempi: 20,126
