Salta al contenuto principale
Un tablet da 10 pollici creato da Google e Samsung per la linea di prodotti Nexus.
Help required removing the front screen
I have a nexus with some water damage, I have managed to dry it out and it boots okay. I have a small water drop in between the front screen and the LCD. Is there a way of removing the front screen without removing the entire LCD display?
Questa è una buona domanda?
Punteggio 0
1 Commento
Bother, I already dried the device out and I can't get to this bit.
I think it will have to be a permanent reminder not to the drop the tablet in the bath!
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi!
Unfortunately you have to work your way trough the device to get to the LCD & digitizer assembly. It also seems that they are glued together, but you could maybe let that drop of water dry out a few days?
Punteggio 1
Aggiungi la tua risposta
Daniel Marsh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 13
Tutti i Tempi: 309
