Salta al contenuto principale
La Xbox One S, progettata da Microsoft Corporation, è stata lanciata nell'agosto 2016. La Xbox One S è una riprogettazione della Xbox One.
Help with stuck Xbox Controller B button
So, I have a Xbox One S controller with a stuck B button. I called Microsoft and they are sending me a new one and letting me keep the old one. So, I was wondering if I could fix the messed up button. It registers as pressed constantly but is not physically stuck. Has been tested on 2 Xbox Ones and a PC.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione prescelta
You can try this teardown below and see is something is possibly jamming the B button under the rubber as shown in step 8. It might be a software issue as well, but it's worth a shot to take it apart if it's not working anyways.
Smontaggio del controller wireless per Xbox One
Punteggio 4
4 Commenti:
Thanks! I’ll try this. It’ll have to go on my teardown table tomorrow!
da
This worked! The button was caught somehow on the paneling. I broke the haptic motor doing it but I have a soldering gun...
da
Ayyy, good to hear. Glad you figured it out and good luck with the re-soldering
da
I don't know how to solder I have a brand new well two-week-old Xbox One controller and the a button is sticking it's not dirt and I don't know how to solder I also don't take apart controllers I don't have that level of high-tech is there help please I need to fix my controller and I'm kind of limited Q-tips and alcohol fix dirt it's not dirt
da
Rubbing alcohol on a q tip wipe around edge of button and press the button rapidly no more sticky button your welcome
Punteggio 0
1 Commento:
As I said, it is not physically stuck, I don’t eat and game. It’s something within the device, it clicks just fine.
da
Aggiungi la tua risposta
Reed Crosby sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 52
Tutti i Tempi: 54,689
