Salta al contenuto principale
Il ZTE Max XL è il modello di punta dei telefoni cellulari ZTE. È dotato di un touchscreen da 6" e di una batteria da 3990 mAh.
Phone will not charge
My cell phone will go into charging mode but it decreases the battery percentage and reads as a USB corb but it is plugged into the wall can u please help me?I've soft reset it, wipe cache everything nothing is working was working last night
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
I believe this is a battery issue. Which should be cheap
I have the same problem. I found i way to turn boot the phone still though. I just have to stick a pin or similar thing in a little space in the back of the phone and hold it there for about 3 seconds and the phone will be booted. To wake the screen i just downloaded an app where i can use the power button to wake it and also downloaded an app where i can use the sensor beside to front camera to wake it.
Or charger port, which is daughter board
http://www.ebay.com/p/2x-zte-max-xl-n956...
Can't seem to find proper guide
Smontaggio ZTE ZMax Pro (Z981)
Or it's charging circuit and requires microsoldering. Not for beginners
Punteggio 2
Aggiungi la tua risposta
Irisht-raw 94 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 15
Tutti i Tempi: 8,969
