Salta al contenuto principale
The UE Mini Boom is a very compact Bluetooth speaker that has a built-in rechargeable battery, speakerphone capabilities, a line input, and ruggedized design.
Battery replacement for UE Mini Boom?
Is it possible change battery on this device? If yes do anyone know how to do it.
Thank you very much
Update (08/28/2017)
Thank you very much for your help.Well i'v seen already this movies and i manage to open it,also i check the port and looks that the power is coming in,also i took out the battery and test it separetly with external charger and it shows that it charging.How ever when i put every thing together it doesn't show any signs of live.Any way if any body know how to deal with it i will very much appreciate
Questa è una buona domanda?
Punteggio 1
1 Commento
Getting into the UE Mini Boom is not that difficult, and soldering in a new battery should be easy; but what to replace the battery with? I've got model S-00136.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Sorry we don't have any IFIXIT guides for the Mini Boom. Here is a good YouTube Vid that shows a person opening one up: How to open logitech mobile boombox for fixing & UE Miniboom reassembly
Once you get it open you should be able to check the USB port to make sure its working using a Volt meter often the port breakdown so the battery won't charge. If the battery its self is bad you'll need to search the web for a replacement using the info from the battery. Good Luck!
Punteggio 2
Aggiungi la tua risposta
S.Goland sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 27
Tutti i Tempi: 4,453
