Salta al contenuto principale
L'HTC Desire è il primo smartphone della serie Desire sviluppato da HTC.
I dont know what happened ...
when i turn on my phone it keeps repeating the welcome window repeatedly.....
Questa è una buona domanda?
Punteggio 2
1 Commento
Phone is on but no picture no service
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
rica, did anything happen to the phone? Any firmware or software updates? Anyhow try this first and see what happens. Hold the Volume - button then press the power button once. You should boot into FASTBOOT. Select BOOTLOADER, and select clear data or something like that. This will do a factory reset for your phone. You may lose your info on there so make sure you have some sort of back up for contacts etc. http://www.htc.com/europe/howto.aspx?id=... and here http://www.knowyourcell.com/htc/htc-desi... is more info Let us know if this helped so we can continue to assist you if not. Good luck.
Punteggio 1
I had the same problem, and after days of searching on internet I realized the problem is the overheating of the CPU which is a hardware problem. Maybe you guys can fix the problem. Good luck
Punteggio 0
i was restoring the factory setting and during restoring it become dead . i dont know wht happend . can anyone help me to resolve it .????
Punteggio 0
Aggiungi la tua risposta
rica sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 16
Tutti i Tempi: 5,404
